Введение
This is a guide that explains how to replace the trackpad for the HP 15-dy2072dx. The trackpad may need replacement in case it stops working, cracks, or wears out.
The trackpad is responsible for allowing users to move their pointer and click on items without the need for a external mouse. Trackpads are usually found on laptop to aid with portability.
Выберете то, что вам нужно
Flip the laptop over and open the lid.
Separate the bottom panel from the main body by using the iFixit opening tool.
Remove the five M2x6 screws that secure the battery with a Phillips #0 screwdriver.
Grab the sides of the battery and gently pull the battery until it disconnects from the connector on motherboard.
Lift the battery up and out.
Lift the black ribbon covering the screws.
Unscrew the top three M2x3 Phillips screws.
Flip up the locking flap holding the trackpad ribbon in place.
Pull the ribbon straight out of its socket.
