Введение
Here is a step by step way to remove and replace your battery for the HP 15-f004dx. Please make sure that you have tested the battery following the instructions listed here under Testing the Battery.
If your battery fails the tests and needs to be replaced, you are able to purchase a new battery here once you are able to identify the correct battery for your specific computer model.
Выберете то, что вам нужно
After testing the battery and discovering that it needs to be replaced, you will begin by placing the computer upside-down on a flat surface.
Locate a switch in the upper left corner with a lock symbol next to it.
Slide the switch to the right until you see an unlocked symbol on the opposite side.
There is another switch on the opposite side of the computer with a battery symbol next to it.
Slide this switch to the left and the battery should detach from the computer.
To completely remove the battery, simply pull the battery away from the computer.
