Введение
Technical problems with a motherboard, caused by improper handling, humidity, power supply spikes, or many other reasons, can lead to a great deal of deterioration of user experience. This guide will help you understand the process of replacing the motherboard on the HP 15-f162dx laptop.
Before the start of the replacement process, make sure to disconnect the laptop from its power supply and place the device on a flat work surface with plenty of space around it to avoid mishandling the delicate components.
Выберете то, что вам нужно
Use a Flathead 2.5 mm Phillips screwdriver to remove all of the screws on the backside of the laptop.
There are 14 screws on the back plate in total, make sure to remove them all before proceeding.
Once all screws have been removed , place the laptop on a flat surface and insert a metal spudger in a gap between the top side coverings.
Once inserted, move the spudger around the base, lifting the top edge about quarter of an inch. Gently go around the edge repeating the action.
After all of the inside latches have been dislodged, remove the front cover. Now is a good time to clean the dust that collects in the device after prolonged use.
Use Phillips JIS J00 screwdriver to undo the screws that attach the motherboard to the back cover.
Again, make sure to apply only a gentle pressure when undoing the screws.
Locate and disconnect the wires that are connected to the motherboard.
Instead, you can use a credit card or a plastic spudger included in the Essential Electronics Toolkit.
After the wires have been disconnected, gently lift the motherboard out of the laptop.
