HP 15-f162dx Motherboard Replacement
Выберете то, что вам нужно
  1. HP 15-f162dx Motherboard Replacement, Battery: шаг 1, изображение 1 из 1
    • Pull back the lock.
  2. HP 15-f162dx Motherboard Replacement: шаг 2, изображение 1 из 1
    • Take off the battery
  3. HP 15-f162dx Motherboard Replacement, Motherboard: шаг 3, изображение 1 из 1
    • Use a Flathead 2.5 mm Phillips screwdriver to remove all of the screws on the backside of the laptop.
    • There are 14 screws on the back plate in total, make sure to remove them all before proceeding.
    • Apply gentle pressure when undoing the screws to preserve the condition of screw heads for future repairs or servicing.
  4. HP 15-f162dx Motherboard Replacement: шаг 4, изображение 1 из 1
    • Once all screws have been removed , place the laptop on a flat surface and insert a metal spudger in a gap between the top side coverings.
    • Once inserted, move the spudger around the base, lifting the top edge about quarter of an inch. Gently go around the edge repeating the action.
    • The sharp popping sound that the latches on the inside will produce is normal and does not signify anything being broken.
    • While some force will be required in this step, make sure not to over-apply pressure since extra force might break the plastic latches.
    • After all of the inside latches have been dislodged, remove the front cover. Now is a good time to clean the dust that collects in the device after prolonged use.
  5. HP 15-f162dx Motherboard Replacement: шаг 6, изображение 1 из 1
    • Use Phillips JIS J00 screwdriver to undo the screws that attach the motherboard to the back cover.
    • Again, make sure to apply only a gentle pressure when undoing the screws.
    • Be very careful: If the metal head of the screwdriver slips during the process, it can damage the motherboard. While not relevant in case of removing a broken motherboard, it is crucial while putting in a new one.
  6. HP 15-f162dx Motherboard Replacement: шаг 7, изображение 1 из 3 HP 15-f162dx Motherboard Replacement: шаг 7, изображение 2 из 3 HP 15-f162dx Motherboard Replacement: шаг 7, изображение 3 из 3
    • Locate and disconnect the wires that are connected to the motherboard.
    • Do not use any kind of metal instrument to assist you in this process since it can damage the contacts of the wires.
    • Instead, you can use a credit card or a plastic spudger included in the Essential Electronics Toolkit.
    • After the wires have been disconnected, gently lift the motherboard out of the laptop.
Заключение
Abdulrahman Bogshan
Участник с: 10/02/18
322 Репутация
Автор 3 руководств
Команда
Eastern Washington University, Team S2-G7, Munoz Fall 2018 Участник Eastern Washington University, Team S2-G7, Munoz Fall 2018
EWU-MUNOZ-F18S2G7
3 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 10
За всё время: 610
