Введение
The HP-f162dx can experience RAM failure with regular software. Signs of RAM failure include crashing, a blue background screen, and frequent freezing. However, it is easy to fix with basic tooling. Before beginning the repair, a user must have a size 0 screwdriver and an eight-gigabyte RAM memory card.
NOTE: use an anti-static wrist strap when working to prevent circuitry damage.
Выберете то, что вам нужно
Use a small Phillips screwdriver to remove the four screws from the RAM cover. Remove the RAM cover.
Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it.
Repeat steps in reverse order to reassemble the computer with new RAM
