Введение
If the button board is not responding, use this button board replacement guide. You will need to follow the prerequisite guides before following this guide.
Выберете то, что вам нужно
Slide the latch towards the center of the laptop so the unlock emblem appears.
Place your finger on the left latch and slide it towards the center of the laptop.
Using either a credit card or flat spudger, wedge it between the palm rest and the keyboard.
Using a Phillips #00 screwdriver, remove all the 5 millimeter screws located on the bottom of the laptop.
Using the spudger, remove the two rubber feet that are located near the battery.
Еще один человек закончил это руководство.
