Введение
This guide will walk you through step by step on how to replace the speakers on the HP 15-g010dx laptop. You will need about 10-15 minutes to do this replacement. Before you embark make sure that you have your replacement speakers ready to install.
Выберете то, что вам нужно
Slide the latch towards the center of the laptop so the unlock emblem appears.
Place your finger on the left latch and slide it towards the center of the laptop.
Using either a credit card or flat spudger, wedge it between the palm rest and the keyboard.
Using the Phillips #00 screwdriver, remove the 5 millimeter screws that are visible.
Using the spudger, remove the two rubber feet that are located near the battery.
Now remove the screws indicated by an arrow stamped into the metal, located where the keyboard was.
Take the metal spudger and gently insert in between the palm rest and the body.
Work the spudger in small increments around the palm rest while lifting it up in the air.
2 участников успешно повторили данное руководство.
