Введение
Is your computer running too slow and you want to replace your hard drive with an SSD or one with more RPMs? Then this is the guide for you! Replacing the hard drive in an HP 15-g071nr laptop is easier than you may think, so do not be intimidated. NOTE: Turn off laptop before starting this guide.
Выберете то, что вам нужно
Press the tabs at the corners of the laptop at the same time to release the battery.
Using your Phillips #0 screwdriver, remove all of the screws on the back case.
Carefully move the iFixit opening tool along the seam of wrist rest until you can remove it.
Remove the wrist rest once it comes loose from the body.
Remove the two screws with the Phillips #0.
Gently pull the hard drive out of its SATA connection to the motherboard.
Attach the loose data cable to the new drive.
