Введение
In this guide, you will remove and/or replace the audio speakers within the HP 15-r137wm TouchSmart. The speakers are where any audio from your device comes out of. These small, compact speakers can reach between 50 and 90 decibels. Also, the screws which attach the speakers to the housing have shock absorbents so that vibration is not an issue when playing audio.
Выберете то, что вам нужно
Remove all ten (10) 5.5 mm Phillips #0 screws.
Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95
Use a wide plastic opening tool to pry off the top casing.
Lift the cover off carefully as there are wires still attached to internal components.
Move the keyboard slightly out of the way to locate the connection.
Disconnect the small wire protruding from the motherboard underneath the metal plate.
Locate the connection between the power button and the connecting cable.
Remove the cable from the motherboard carefully.
Remove the four (4) 2.5mm by 3.5mm Phillips #0 screws from the metal retaining plate.
Lift the metal retaining plate off and away from the device.
Disconnect the power source from the motherboard.
Lift the speakers away from the housing by sliding them out from under the motherboard.
