Введение
In this replacement guide you will be removing and/or replacing the cooling fan inside of your HP 15-r137wm TouchSmart. The cooling fan is used to cool down internal processors so that the device does not overheat. Also, it prevents dust and other harmful substances from entering the device as it blows air outside the device.
Выберете то, что вам нужно
Remove all ten (10) 5.5 mm Phillips #0 screws.
Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95
Use a wide plastic opening tool to pry off the top casing.
Lift the cover off carefully as there are wires still attached to internal components.
Move the keyboard slightly out of the way to locate the connection.
Disconnect the small wire protruding from the motherboard underneath the metal plate.
Locate the connection between the power button and the connecting cable.
Remove the cable from the motherboard carefully.
Remove the four (4) 2.5mm by 3.5mm Phillips #0 screws from the metal retaining plate.
Lift the metal retaining plate off and away from the device.
Locate the small connection on the motherboard and disconnect it by slowly pulling it away from the motherboard.
