HP 15-r137wm TouchSmart Front Panel Assembly Replacement
Выберете то, что вам нужно
  1. HP 15-r137wm TouchSmart Front Panel Assembly Replacement, Front Panel Assembly: шаг 1, изображение 1 из 3 HP 15-r137wm TouchSmart Front Panel Assembly Replacement, Front Panel Assembly: шаг 1, изображение 2 из 3 HP 15-r137wm TouchSmart Front Panel Assembly Replacement, Front Panel Assembly: шаг 1, изображение 3 из 3
    • Make sure that the device is powered off and unplugged before removing components.
    • Remove all ten (10) 5.5 mm Phillips #0 screws.
    • Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
  2. HP 15-r137wm TouchSmart Front Panel Assembly Replacement: шаг 2, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Anti-Static Wrist Strap
    $7.95
    Купить
    • Use a wide plastic opening tool to pry off the top casing.
    • Be cautious not to crack the casing near the keyboard as it is quite fragile.
    • Lift the cover off carefully as there are wires still attached to internal components.
    • After panel is removed, use an anti-static wrist strap to ensure the motherboard does not get any external shocks from static discharge.
  3. HP 15-r137wm TouchSmart Front Panel Assembly Replacement: шаг 3, изображение 1 из 1
    • The connection for the track pad is still connected.
    • Move the keyboard slightly out of the way to locate the connection.
    • Disconnect the small wire protruding from the motherboard underneath the metal plate.
  4. HP 15-r137wm TouchSmart Front Panel Assembly Replacement: шаг 4, изображение 1 из 2 HP 15-r137wm TouchSmart Front Panel Assembly Replacement: шаг 4, изображение 2 из 2
    • Locate the connection between the power button and the connecting cable.
    • Do not lift the front panel off to far as the cable is still attached.
    • Remove the cable from the motherboard carefully.
Заключение
2 участников успешно повторили данное руководство.
Ross B Jacques
Участник с: 10/18/17
857 Репутация
Автор 7 руководств
Команда
UMass Dartmouth, Team S4-G4, Julie Fall 2017 Участник UMass Dartmouth, Team S4-G4, Julie Fall 2017
UMASSD-JULIE-F17S4G4
3 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 430
