Введение
During the process, be careful with the placement of removed screws. This back panel disassembly is required to access all internal components.
Выберете то, что вам нужно
Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
5 участников успешно повторили данное руководство.
