Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
To remove the battery, simply push the tabs towards each other.
Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
Pull outwards on the disk reader to remove from main frame.
Unscrew all four screws connecting the heatsink to the motherboard.
After loosening all screws remove the heat sink and store it in a safe place.
After removing the heat sink, disconnect the cable connecting the fan to the motherboard.
