Введение
Use this guide to replace the hard drive in your HP 17-bs049dx.
Выберете то, что вам нужно
Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
Just for clarity, there are 8 screws to be removed, four that are always visible and four that are hidden under the outer ends of the rubber feet.
Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
Remove screw (7.51mm) on USB port with "Phillips 0 Screwdriver".
Lift the USB port over and away from hard drive.
Lift rubber black tabs located on the hard drive upwards.
Disconnect hard drive from motherboard by pulling towards you.
12 участников успешно повторили данное руководство.
2 Комментариев
How much force am I required to put while lifting the back panel to access the internal components? I can go hulk on it but then I wouldn’t have a laptop later…
