Введение
The motherboard is the link between all the different components in the computer. If you've had your device for a while and it malfunctions, you might assume it's a problem with the motherboard. Before you start opening up the device, check connection and peripherals and listen for beeps.
Выберете то, что вам нужно
Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
Remove screw (7.51mm) on USB port with "Phillips 0 Screwdriver".
Lift the USB port over and away from hard drive.
Lift rubber black tabs located on the hard drive upwards.
Disconnect hard drive from motherboard by pulling towards you.
Remove the screws (7.51mm) with a Phillips #0 screwdriver.
Once all of the screws are removed, remove the motherboard from the device.
Еще один человек закончил это руководство.
