Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
The USB port is the component that accepts the entry and removal of digital transfer.
Запчасти
Детали не указаны.
  1. To remove the battery, simply push the tabs towards each other.
    • To remove the battery, simply push the tabs towards each other.
    • The battery will come out with force, be sure to keep anything fragile away from the laptop during this process.
  2. Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
    • Rubber tabs will require force to access screws.
  3. Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
    • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
  4. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Купить сейчас
    Купить сейчас
  5. Pull outwards on the disk reader to remove from main frame. This removal will require force.
    • Pull outwards on the disk reader to remove from main frame.
    • This removal will require force.
    • All screws must be removed before removing disk reader.
  6. Lift back panel to access internal components.
    • Lift back panel to access internal components.
    • You will need to use force to pry it open.
  7. Remove the two screws using a Phillips #0 screwdriver. Remove the two screws using a Phillips #0 screwdriver.
    • Remove the two screws using a Phillips #0 screwdriver.
  8. At both ends of the connector ribbon, unclip both connectors. Gently remove the ribbon from the unlatched area. Gently remove the ribbon from the unlatched area.
    • At both ends of the connector ribbon, unclip both connectors.
    • Gently remove the ribbon from the unlatched area.
Заключение
Logan McCarty
Участник с: 01.10.2018
232 Репутация
Автор 2 руководств
Команда
University of North Texas, Team S7-G2, Thompson Fall 2018 Участник University of North Texas, Team S7-G2, Thompson Fall 2018
UNT-THOMPSON-F18S7G2
6 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 87
