Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
To remove the battery, simply push the tabs towards each other.
Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
Pull outwards on the disk reader to remove from main frame.
At both ends of the connector ribbon, unclip both connectors.
Gently remove the ribbon from the unlatched area.
