Введение
If your computer is overheating, you may need to replace your CPU cooling fan. This procedure involves the removal of a few screws and disconnecting power cords. NOTE: when ordering the CPU cooling fan, you need the assembly that includes the heat sink.
Выберете то, что вам нужно
Slide and hold the right tab to the left, while gently pushing out the battery with your thumbs
Use a spudger or Jimmy to lift the plastic back cover starting from the back right side near the vents.
Remove the back cover of the device by continuing to lift the plastic around the entire perimeter of the device.
Using the Phillips #0 screwdriver, unscrew four heat-sink screws (These will unscrew, but will stay attached to the heat-sink), and one screw towards the top.
Disconnect the power cable.
Еще один человек закончил это руководство.
