HP 5406 zl Switch Chassis (J8697A) Replacement
Выберете то, что вам нужно
  1. HP 5406 zl Switch Chassis (J8697A)  Replacement, Identifying the modules: шаг 1, изображение 1 из 2 HP 5406 zl Switch Chassis (J8697A)  Replacement, Identifying the modules: шаг 1, изображение 2 из 2
    • The equipment comes with two modules to install a supervisor card and 6 expansion slots for compatible modules.
    • J8726A Management Module.'
    • J8705A Module 20p 10/100/1000 + 4p SFP.
    • 'RESET' and 'CLEAR' buttons used for: 'CLEAR' Erase only the access passwords when pressed for at least 1 second. 'RESET' Restores factory default settings when pressed in a specific pattern.
    • RS232 console port; any baud rate from 2400 to 115200 (the switch automatically detects the speed) 8 data bits, 1 stop bit, no parity and flow control set to None
    • USB port
    • J4858C - HP Gigabit-SX-LC Mini-GBIC
  2. HP 5406 zl Switch Chassis (J8697A)  Replacement, Removing the expansion modules: шаг 2, изображение 1 из 3 HP 5406 zl Switch Chassis (J8697A)  Replacement, Removing the expansion modules: шаг 2, изображение 2 из 3 HP 5406 zl Switch Chassis (J8697A)  Replacement, Removing the expansion modules: шаг 2, изображение 3 из 3
    • The modules can be removed with the equipment turned on, with the exception of the 'Management Module'.
    • Loosen the screws, the screw contains a spring and once it is loose it will be ejected and will remain in the equipment.
    • To remove the module, pull the handles that are on the bottom of the module.
  3. HP 5406 zl Switch Chassis (J8697A)  Replacement, Removing the Managment Module: шаг 3, изображение 1 из 3 HP 5406 zl Switch Chassis (J8697A)  Replacement, Removing the Managment Module: шаг 3, изображение 2 из 3 HP 5406 zl Switch Chassis (J8697A)  Replacement, Removing the Managment Module: шаг 3, изображение 3 из 3
    • Do not remove while the equipment is on
    • Following the same procedure above, loosen the screws and pull the levers of the module to remove it.
    • RAM Memory
    • Flash card
Заключение
Еще один человек закончил это руководство.
Особая благодарность этим переводчикам:
es en
100%
Luis Annielпомогает нам починить мир! Хотите внести свой вклад?
Начните переводить ›
Eneider Colina
Участник с: 09/20/13
2 362 Репутация
Автор 9 руководств
Команда
Comunidad para traductores de español Участник Comunidad para traductores de español
Community
22 членов
Автор 186 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 31
За всё время: 2,031
