Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If the device volume and/ or power buttons are unresponsive then it may be necessary to replace them. The most challenging step to fix both buttons is removing the back cover. The tools listed (or similar) are necessary for both buttons to function properly.
Выберете то, что вам нужно
Use the T5 Torx screwdriver and remove the T5x3mm screws on all four corners of the device.
Using the plastic opening tool, push in between the front, then slide it around.
Slide the plastic opening tool all the way around the tablet to separate the back cover.
Continue sliding the plastic opening tool around the tablet until the cover fully separates from the device.
Remove the back cover.
The power and volume buttons are on the side of the device. Locate these buttons to begin the replacement process.
Еще один человек закончил это руководство.
