Введение
Need to remove your back cover to replace it or access internal parts? Use this guide to get it off (requires T5 Torx Screwdriver)
Выберете то, что вам нужно
Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
Use the plastic opening tool to push in between the front and the back of the tablet.
Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
Remove the back cover.
