Введение
Changing the battery may be necessary if the device wont power up, or doesn't seem to hold a charge anymore. The most challenging step to changing the battery is removing the back cover. Acquiring the tools listed (or similar) are absolutely necessary for a complication free battery replacement.
Инструменты
Запчасти
Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
Use the plastic opening tool to push in between the front and the back of the tablet.
Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
Remove the back cover.
Push out the battery connector using the spudger.
Swing the battery connector clear of the connector socket.
To reassemble your device, follow these instructions in reverse order. Use new double sided tape to secure the new battery.
Еще один человек закончил это руководство.
