Введение
If you find yourself needing to replace your HP Beats Special Edition 15-p390nr fans, use this guide to help you go through the process successfully.
Выберете то, что вам нужно
Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
Once screws are removed you may now remove the optical drive.
Remove the hidden 3mm screw in the optical drive port.
Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
The shoulder caps are removable. Underneath there are 2 additional screws.
Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
