Введение
If you find yourself needing to replace the motherboard for your HP Beats Special Edition 15-p390nr, this guide will help you do so.
Запчасти
Никакие детали не требуются.
  1. Turn computer off before starting.
    • Turn computer off before starting.
    • Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
  2. Some screws may be hidden under a screw cover.
    • Some screws may be hidden under a screw cover.
    • Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Screw cover may fly when removing.
    • Once screws are removed you may now remove the optical drive.
    • Remove the hidden 3mm screw in the optical drive port.
    • Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
    • Popping noises are normal
    • Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
    • Unclip wires connected to the motherboard and remove keyboard from the device.
    • 17 screws should be removed up to this point.
    • Remove screws from the motherboard.
    • 11 screws should be removed from the motherboard
    • Unclamp wire strips from motherboard.
    • Detach by lifting the motherboard up and flip the motherboard over.
    • Unclip wifi card for further procedures
Заключение
Michelle
Участник с: 02.10.2018
109 Репутация
1 Guide authored
Команда
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 4
За 30 дней: 36
За всё время: 50
