Введение
Sometimes it's necessary to replace a defective battery or remove it to test an AC adapter. This guide shows how to replace the battery of the HP Chromebook 11 G4.
Выберете то, что вам нужно
Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
Pry off the rubber pads to reveal a screw under each pad.
Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
Slide the spudger along the gap, applying downward pressure to separate the two components.
Lift the bottom of the keyboard assembly to reveal the internal components of the device.
Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
Disconnect the bundled power cable by grasping both edges with your fingers and pulling.
27 участников успешно повторили данное руководство.
7 Комментариев
Christopher, your step by step is superb! I am one grateful chicky. Thanks to your guide, I didn't have to replace my laptop! It worked like a charm, despite not owning a spudger. I had to improvise and used a butter knife for tha unclipping of keyboard and my fingernails to unclip tha component clips and didn't even damage my rubber pads! Thank you so very much!!!
Video was great. Disassembly and assembly took about 1 hour
Measured power supply voltage as 6V. Not sure if this is enough to bring down the computer. Spec says is should be 7.7Vdc.
Excellent! So easy to follow! Thank you for the well written guide and tips.
