Введение
The motherboard is the electronic circuit board of which all other components are connected to. A broken motherboard is a broken computer.
Выберете то, что вам нужно
Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
Pry off the rubber pads to reveal a screw under each pad.
Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
Slide the spudger along the gap, applying downward pressure to separate the two components.
Lift the bottom of the keyboard assembly to reveal the internal components of the device.
Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
Remove the cable at the top left of the motherboard by grabbing the male connector and applying force in the direction of the wires away from the motherboard.
Disconnect the battery wires from the motherboard by applying pressure on the male connector away from the motherboard.
Disconnect the wire bundle on the bottom right of the motherboard by pulling the black male connector away from its socket on the motherboard.
Use a fingernail or a spudger to flip up the black tab on the zero insertion force connector located at the top of the motherboard.
Remove the cable by pulling away from the motherboard.
Use a fingernail or a spudger to flip up the white tab on the zero insertion force connector on the bottom left of the motherboard.
Lift the left edge up and away from the base of the laptop.
Remove the motherboard.
Еще один человек закончил это руководство.
