Введение
This is a replacement guide for the HP Chromebook 11 G5 keyboard. The main purpose of the steps below is to show you how to replace the keyboard. The keyboard is required to input characters and perform various manual functions. Symptoms of a defective keyboard include unresponsive or broken keys. If these steps are followed carefully and correctly the keyboard should be easily replaced. Be sure to power off your device before beginning the replacement process.
Выберете то, что вам нужно
Remove four large rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
Remove two smaller rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
Wedge the flat-end of a metal spudger between the base of the device and the keyboard assembly while applying downward pressure. Slide the spudger across the entirety of the gap until the two components separate.
Disconnect the two ribbon cables connected to the motherboard by using the pointed end of a spudger to lift the plastic connector lids to allow the ribbon cables to be gently removed by hand.
3 участников успешно повторили данное руководство.
