Введение
This is a replacement guide for the HP Chromebook 11 G5 screen. The main purpose of the steps below is to show you how to replace the screen. The screen is the most important output device of the Chromebook and is required to display information visually. Symptoms of a defective screen include an unresponsive, black screen after the device has been powered on and streaking lines or distorted images being displayed. If these steps are followed carefully and correctly the screen should be easily replaced. Be sure to power off your device before beginning the replacement process.
Выберете то, что вам нужно
Open the lid as far as possible.
Slide your spudger into the bezel of the laptop until it appears on the other side.
Make your way around the bezel with the spudger while gently prying up the bezel to snap it out of place.
Hold the bezel on both sides, and twist the bezel repeatedly until the bottom bezel snaps out of place.
Identify the eDP 30-pin connector and use the sharp end of the spudger to peel off a corner of the tape over the connector.
Use your fingers to peel off the rest of the tape.
Hold both sides of the tape and gently push back the connector to disconnect the display.
2 участников успешно повторили данное руководство.
