Введение
This guide will show you how to replace a broken or defective screen on a Chromebook 11 G6 EE.
Выберете то, что вам нужно
Use a plastic pick or spudger around the edges of the bezel to pop the clips loose.
Push down on the seem between the hinge cover and bezel to release the clips holding the two together.
When successful, there will be a small seam visible, as shown in the second photo.
Open the computer to 180º to make it easier to remove the hinge cover
Insert a spudger into one side and pry up to remove the cover
Remove the four M2.5x2 PH#0 screws holding the LCD in the display.
Flip the screen over onto the keyboard.
Peel the sticker holding the screen connector in place.
The sticker is difficult to remove. I use a spudger to get it started and grab it with pliers or tweezers to pull it up.
Pull the connector loose. It should pop out very easily
Slide the connector into the socket on the new screen.
The new screens do not come with the sticker. I recommend pulling the sticker off of the old screen and using it to hold the connector in place for the new screen.
Remove the protective film from the new screen and re-attach the screen with the screws.
Snap the plastic frame back into place. It should snap back in very easily but be careful not to put extra pressure on the screen.
Before reattaching the bezel, we have to apply new adhesive tape to the inside edge in place of the old adhesive. Before that, we have to remove the old adhesive
The easiest way is to use the flat end of a fresh spudger to scrape the adhesive away. If it's being stubborn, a quick few seconds with a heat gun makes things a whole lot easier.
Add new tape
Check the screen to make sure it is functioning properly and be sure to check the camera to make sure the connection did not come loose during repair.
9 участников успешно повторили данное руководство.
