Введение
The motherboard is the primary piece of circuitry that helps keep your laptop running. After troubleshooting through the possible issues with the motherboard and determining that it needs a replacement, you can follow these steps in order to accomplish that goal. This guide will walk you through the steps of replacing the motherboard in your HP Chromebook 11 G8 EE.
Note that there are many symptoms to a failing motherboard such as a loose connection that is a lot less costly than a replacement.
Выберете то, что вам нужно
Use a Phillips #1 screwdriver to remove:
Four 7 mm screws.
Two 8 mm screws.
Flip the device over and open the lid.
Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
Lift the keyboard assembly from the laptop towards you, away from the screen.
Peel back the film over the speaker's motherboard connector.
Disconnect the speaker cable from the connector on the motherboard.
Remove the four 3.5 mm screws from the base enclosure with a Phillips #1 screwdriver.
Disconnect the battery cable from the motherboard by pulling the connector straight out of its motherboard port.
Flip the two black lock bars on the ZIF connectors using tweezers.
Disconnect both ribbon cables from the motherboard using the tweezers.
Peel back the film and lift the lock bar on the display panel cable with tweezers.
Disconnect the display panel connector with tweezers.
Remove the six 3.5 mm screws with a Phillips #1 screwdriver.
Lift the USB-C bracket off the motherboard.
