HP Chromebook 11-2210nr Battery Replacement
Выберете то, что вам нужно
  1. HP Chromebook 11-2210nr Battery Replacement, Battery: шаг 1, изображение 1 из 2 HP Chromebook 11-2210nr Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • Position your closed laptop face down to remove the 9 visible 6 mm screws using a Phillips #1 screwdriver.
  2. HP Chromebook 11-2210nr Battery Replacement: шаг 2, изображение 1 из 3 HP Chromebook 11-2210nr Battery Replacement: шаг 2, изображение 2 из 3 HP Chromebook 11-2210nr Battery Replacement: шаг 2, изображение 3 из 3
    • Use a metal spudger to remove the two bottom rubber pads located closer to the hinge of the laptop.
    • Remove the two additional 6 mm screws located beneath the rubber pads using the Phillips #1 screwdriver.
    • The other two bottom rubber pads do not have screws beneath them.
  3. HP Chromebook 11-2210nr Battery Replacement: шаг 3, изображение 1 из 3 HP Chromebook 11-2210nr Battery Replacement: шаг 3, изображение 2 из 3 HP Chromebook 11-2210nr Battery Replacement: шаг 3, изображение 3 из 3
    • Turn the Laptop over, and with the metal spudger start to run it along the plastic seam to pry it off.
    • You will hear popping sounds when you are sliding the spudger along the device.
    • For an easier removal, start from the sides and work your way in to the corners.
    • Be careful when using the metal spudger as it could cause damage to the internals of the device. Don't push the spudger too deeply into the seam.
  4. HP Chromebook 11-2210nr Battery Replacement: шаг 4, изображение 1 из 3 HP Chromebook 11-2210nr Battery Replacement: шаг 4, изображение 2 из 3 HP Chromebook 11-2210nr Battery Replacement: шаг 4, изображение 3 из 3
    • Carefully lift the keyboard up and gently place it towards you until the two ribbon wires become visible and place the keyboard down.
    • Locate where the two ribbon wires are being held in place by two locks.
    • This does not disconnect the keyboard from the laptop just yet.
  5. HP Chromebook 11-2210nr Battery Replacement: шаг 5, изображение 1 из 3 HP Chromebook 11-2210nr Battery Replacement: шаг 5, изображение 2 из 3 HP Chromebook 11-2210nr Battery Replacement: шаг 5, изображение 3 из 3
    • Using the nylon spudger, push the plastic clasps holding the two ribbon wires up to properly disconnect the wires.
    • It is important to use the nylon spudger for this step to avoid any metal on metal circuit damage.
    • This step completely disconnects the keyboard to allow safe removal.
  6. HP Chromebook 11-2210nr Battery Replacement: шаг 6, изображение 1 из 2 HP Chromebook 11-2210nr Battery Replacement: шаг 6, изображение 2 из 2
    • Remove the six 4 mm screws holding the battery in place with a Phillips #1 screwdriver.
  7. HP Chromebook 11-2210nr Battery Replacement: шаг 7, изображение 1 из 3 HP Chromebook 11-2210nr Battery Replacement: шаг 7, изображение 2 из 3 HP Chromebook 11-2210nr Battery Replacement: шаг 7, изображение 3 из 3
    • Carefully unplug the bundle power cable by pulling both edges towards you.
    • This successfully disconnects the battery from the laptop.
  8. HP Chromebook 11-2210nr Battery Replacement: шаг 8, изображение 1 из 3 HP Chromebook 11-2210nr Battery Replacement: шаг 8, изображение 2 из 3 HP Chromebook 11-2210nr Battery Replacement: шаг 8, изображение 3 из 3
    • Carefully lift the battery and remove it from the laptop.
    • The battery may have an adhesive sticker attached to the bottom, if so apply more force when lifting up.
Заключение
Kimberly Rodriguez
Участник с: 10/02/18
425 Репутация
Автор 2 руководств
Команда
Sam Houston State, Team S11-G3, Blackburne Fall 2018 Участник Sam Houston State, Team S11-G3, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S11G3
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 347
