Введение
This guide will show you the correct way to remove the battery according to an HP Chromebook 11-2210nr in the need to replace a faulty or damaged battery. Once the battery is removed, access to speakers is more accessible.
Выберете то, что вам нужно
Position your closed laptop face down to remove the 9 visible 6 mm screws using a Phillips #1 screwdriver.
Use a metal spudger to remove the two bottom rubber pads located closer to the hinge of the laptop.
Remove the two additional 6 mm screws located beneath the rubber pads using the Phillips #1 screwdriver.
Turn the Laptop over, and with the metal spudger start to run it along the plastic seam to pry it off.
Carefully lift the keyboard up and gently place it towards you until the two ribbon wires become visible and place the keyboard down.
Locate where the two ribbon wires are being held in place by two locks.
Using the nylon spudger, push the plastic clasps holding the two ribbon wires up to properly disconnect the wires.
Remove the six 4 mm screws holding the battery in place with a Phillips #1 screwdriver.
