Введение
This guide will show you how to safely remove a damages or defective LCD screen for replacement according to a HP Chromebook 11-2210nr.
Выберете то, что вам нужно
Remove the one 3 mm screw located underneath both adhesive layers using a Phillips #0 screwdriver.
Using a metal spudger, gently pry the front plastic frame (or bezel) off of the device by inserting the tool along the inside edge of the bezel.
Completely open the screen as far as possible to remove the bottom edge of the bezel from the laptop.
Remove the four black 3 mm screws along the left and right sides of the LCD screen using a Phillips #0 screwdriver.
Gently use the spudger to pry off the tape on top of the gold chip. You may also use your hands to gently remove the tape.
Remove the display cable by gently sliding out the cable away from the LCD screen.
Еще один человек закончил это руководство.
