HP Chromebook 11A G6 EE Speaker Replacement
Выберете то, что вам нужно
  1. HP Chromebook 11A G6 EE Speaker Replacement, Keyboard: шаг 1, изображение 1 из 3 HP Chromebook 11A G6 EE Speaker Replacement, Keyboard: шаг 1, изображение 2 из 3 HP Chromebook 11A G6 EE Speaker Replacement, Keyboard: шаг 1, изображение 3 из 3
    • Remove six 6.6 mm screws from the back case using a Phillips #1 screwdriver.
    • Remove two 8.7 mm screws from the back case using a Phillips #1 screwdriver.
    • Turn the computer over and open it as if you are going to use it.
  2. HP Chromebook 11A G6 EE Speaker Replacement: шаг 2, изображение 1 из 3 HP Chromebook 11A G6 EE Speaker Replacement: шаг 2, изображение 2 из 3 HP Chromebook 11A G6 EE Speaker Replacement: шаг 2, изображение 3 из 3
    • Use the iFixit opening tool to get between the keyboard bezel and the outer edge of the laptop.
    • There are several clips on all sides that will need to be released. You'll hear and feel a pop as each clip is released.
    • Move the opening tool or spudger around the perimeter until you unclipped the keyboard on all sides.
    • This will require a little force. The only thing you don't want to do is push the spudger too deep under the keyboard. You could damage the internals if you do.
  3. HP Chromebook 11A G6 EE Speaker Replacement: шаг 3, изображение 1 из 2 HP Chromebook 11A G6 EE Speaker Replacement: шаг 3, изображение 2 из 2
    • Carefully lift the top of the keyboard up to access the ribbon cables connecting it to the device.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on each connector. Then, pull the connector out.
    • Remove the keyboard and set aside.
  4. HP Chromebook 11A G6 EE Speaker Replacement, Speakers: шаг 4, изображение 1 из 3 HP Chromebook 11A G6 EE Speaker Replacement, Speakers: шаг 4, изображение 2 из 3 HP Chromebook 11A G6 EE Speaker Replacement, Speakers: шаг 4, изображение 3 из 3
    • Release the tape that secures the battery cable connector to the system board.
    • Disconnect the battery cable from the system board. Pull the cable straight out of the connector by the white plastic portion near the connection point.
    • Don't pull the cable out by the wire or it may become damaged.
  5. HP Chromebook 11A G6 EE Speaker Replacement: шаг 5, изображение 1 из 3 HP Chromebook 11A G6 EE Speaker Replacement: шаг 5, изображение 2 из 3 HP Chromebook 11A G6 EE Speaker Replacement: шаг 5, изображение 3 из 3
    • Peel the tape off of the speaker cable connector.
    • Disconnect the speaker cable from the system board. Pull the cable straight out of the connector by the black plastic portion near the connection point. Disconnect the speaker cable from the system board.
    • To avoid damage, don't pull on the wires.
  6. HP Chromebook 11A G6 EE Speaker Replacement: шаг 6, изображение 1 из 3 HP Chromebook 11A G6 EE Speaker Replacement: шаг 6, изображение 2 из 3 HP Chromebook 11A G6 EE Speaker Replacement: шаг 6, изображение 3 из 3
    • Remove two 3.5 mm screws that secure the speakers to the bottom cover using a Phillips #1 screwdriver.
    • Gently pull the speakers out but be mindful of the wires connecting them.
Заключение
William S
Участник с: 09/25/22
575 Репутация
Автор 5 руководств
Команда
Austin Community College, Team 13-2, Watkins Fall 2022 Участник Austin Community College, Team 13-2, Watkins Fall 2022
AUSTINCC-WATKINS-F22S13G2
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 112
