Введение
In this guide, we are going to use words and photos to show the steps of replacing the SD card reader for HP Chromebook14 G5.
When you find out that you cannot access the files on the SD card via your computer, you know that there’s something wrong with your SD card reader and it needs to be replaced.
Make sure to place your SD card separately in another safe place before you start replacing it.
Выберете то, что вам нужно
Remove nine 2.5mm screws embedded in the back cover using the Phillips #0 screwdriver.
Now we can see the SD card reader (in the yellow rectangle) that we need to tear down.
Remove the three 2mm screws around the SD card reader using the Phillips #00 Screwdriver.
