Введение
This guide will show you how to replace the HP Chromebook 14 G5's Wi-Fi card. The Wi-Fi card is built into the laptop, allowing you to connect to wireless internet. If your device is unable to connect to wireless internet, you may have to replace your Wi-Fi card.
Выберете то, что вам нужно
Use a spudger to remove four rubber feet from the corners of the laptop.
Use a spudger to remove seven silicone covers.
Flip the laptop over and open up the display.
Using a opening pick, carefully separate the top housing from the bottom housing by working your way around the perimeter of the laptop and prying it open.
Peel back the black tape covering the battery connector.
Using the spudger, unplug the battery connector from the motherboard.
Carefully lift the keyboard ribbon lock with the spudger and disconnect the keyboard ribbon cable from the motherboard.
Carefully lift the touch pad ribbon lock with the spudger and disconnect the touch pad ribbon cable from the motherboard.
Remove the keyboard assembly from the device housing.
