HP Chromebook 14 Screen Replacement
Выберете то, что вам нужно
  1. HP Chromebook 14 Screen Replacement, Screen: шаг 1, изображение 1 из 2 HP Chromebook 14 Screen Replacement, Screen: шаг 1, изображение 2 из 2
    • We will be replacing the screen on this HP Chromebook. ***Unfortunately I did get a shot of the sweet crack on this screen.
    • We will start by removing this screws on the bottom left and right of the screen, just above the escape key and power button.
  2. HP Chromebook 14 Screen Replacement: шаг 2, изображение 1 из 2 HP Chromebook 14 Screen Replacement: шаг 2, изображение 2 из 2
    • Next will start to remove the front "bezel" with a simple spudger. It is best to start from the bottom (now we here) of the screen. *couldn't resist
    • The bottom will have adhesive/double sided tape that may or may not give you trouble. It is not enough to prevent you from removing the screen, just be aware as it is near the screen circuit board.
  3. HP Chromebook 14 Screen Replacement: шаг 3, изображение 1 из 2 HP Chromebook 14 Screen Replacement: шаг 3, изображение 2 из 2
    • Once removed, we can proceed to remove (4) screws that hold the screen to the laptop case.
    • Marked in blue are the locations for the screws. Screws are closest to screen and on a light silver bracket. Pull screen forward and lay down on keyboard.
  4. HP Chromebook 14 Screen Replacement: шаг 4, изображение 1 из 3 HP Chromebook 14 Screen Replacement: шаг 4, изображение 2 из 3 HP Chromebook 14 Screen Replacement: шаг 4, изображение 3 из 3
    • The ribbon cable is connected at the bottom of the screen. Tape is placed over the connection and it is easily peeled and easy to reuse. I would not advise cutting the tape.
    • Connect your new screen and go backwards through the steps to install.
  5. HP Chromebook 14 Screen Replacement: шаг 5, изображение 1 из 1
    • When re-installed and laptop is closed, check the back hinge area as it does not easily snap back in together. Pat yourself on the back if you can get it all together perfectly!
Заключение
3 участников успешно повторили данное руководство.
Ricky
Участник с: 09/17/13
840 Репутация
Автор 3 руководств
Команда
TechTucson WeFixThat Участник TechTucson WeFixThat
Community
2 членов
Автор 4 руководств
2 Комментариев
Great walkthrough but missed one of the screws in the first step. There's one on the right and left. Nothing a little superglue couldn't fix.
ronguyor - Ответить
That ribbon connector sure is finicky, It's really hard to actually pop it back in without putting too much force to it and bending it up. (for me atleast)
Bo-John Woltman - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 15
За последние 30 дней: 61
За всё время: 10,349
