Введение
When considering a screen replacement it is important to ensure that it is not a connection issue first. Once you determine that you have a tight fitting connection, if the display issues persist then you will need to replace the screen. Fortunately, this is a straight forward process with no special requirements or hazards.
Выберете то, что вам нужно
Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
Open the laptop and place it upright. Remove the keyboard from the device using a plastic spudger or opening tool.
Gently lift the keyboard just enough to expose the ribbons.
Hold the keyboard up to remove the ribbons from the circuit board.
To remove each individual ribbon, grab the blue portion of each ribbon and pull it towards your direction until it is fully detached.
Remove these tabs located at each of the bottom corners of the display.
Using the Phillips #1 screwdriver, remove the single screw located under each of the two tabs.
Insert the plastic opening tool and work it around the entire frame of the display.
As you work the plastic opening tool around the edge, remove the front frame of the device.
Using the Phillips #1 screwdriver, remove the (4) four screws located at the bottom of the display.
Once the screws are removed, lift the display out of the device.
