Введение
A motherboard is essentially the brain of a computer, it controls all the components in a computer to function properly without any errors. Use this guide to replace the motherboard of your device.
Выберете то, что вам нужно
Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
Open the laptop and place it upright. Remove the keyboard from the device using a plastic spudger or opening tool.
Gently lift the keyboard just enough to expose the ribbons.
Hold the keyboard up to remove the ribbons from the circuit board.
To remove each individual ribbon, grab the blue portion of each ribbon and pull it towards your direction until it is fully detached.
Using the Phillips #0 screwdriver, remove the (2) two screws at the bottom of the device.
Remove the taped flat wire from the top of the battery.
Carefully pull away the connector from the top of the battery to the motherboard.
Carefully remove the (3) three plastic strips attached to the motherboard.
Use the blue plastic opening tool to disconnect the connectors. Remove the fan from the motherboard.
Gently lift while using the plastic opening tool to unhinge the motherboard from the computer in an upward pattern.
