Введение
This guide will outline the process to replace a HP Chromebook keyboard in the event when the keyboard is no longer functional and/or to access the hardware underneath the keyboard for an in depth inspection.
Выберете то, что вам нужно
You will need a pair of tweezers and a Phillips screwdriver.
Remove eight 5mm Phillips #0 screws from the back cover of the laptop.
Using a pair of tweezers, remove the five grey silicone covers.
Remove the five 5mm Phillips #0 screws beneath the grey silicone covers.
Place them aside where they will not be lost.
Carefully open your Chromebook case and gently pull the keyboard away from the back panel.
Place the keyboard aside. Inspect for any visual damage or marks.
To reassemble your device, simply follow the steps in reverse. Make sure you replace all screws that were originally removed. Then check that the keyboard is correctly snapped back in place.
