Введение
This guide will walk you through the replacement of an old or corroded motherboard in your HP Chromebook 14-ak041dx. You may need to replace your motherboard if your Chromebook offers continuous slow performance. An upgrade may help it run faster.
Выберете то, что вам нужно
Using a pair of tweezers, remove the five grey silicone covers.
Remove the five 5mm Phillips #0 screws beneath the grey silicone covers.
Place them aside where they will not be lost.
Carefully open your Chromebook case and gently pull the keyboard away from the back panel.
Place the keyboard aside. Inspect for any visual damage or marks.
Инструмент, используемый на этом этапе:Tweezers$4.99
Slide a spudger underneath the white strip over the battery to gently pull the strip away from the adhesive sticking to the battery.
Using a pair of tweezers, grip the black tape connected to the battery, and gently pull back to unplug the battery.
Remove the two 1.5mm Phillips #000 from the copper heat sink on top of the motherboard.
Remove the heat sink from the laptop.
Remove the single 2.5mm Phillips #00 screw from the wireless card.
Gently pull the wireless card from the motherboard to remove it.
Gently pull the wire connector with a pair of tweezers to free it from the motherboard.
Use a pair of tweezers to remove the black ribbon cable from its connector.
Use the tweezers to detach the wire connector from the bottom left corner of the motherboard.
Remove the four Phillips #000 screws holding the motherboard in place.
Remove the motherboard from the laptop.
