Введение
This is a guide for the HP Chromebook 14-ca061dx. In order to repair any internal pieces, you must remove the keyboard. For this guide, you will need the opening tool, the Phillips 64 bit screwdriver with the PH0 head, and spudger.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Tweezers$3.99
Flip the Chromebook to the underside with the hinge at the top.
Remove the seven, small rubber stoppers using angled tweezers.
Flip the Chromebook over and open the cover.
Insert the iFixit opening tool into the edge of the keyboard, near the mouse pad.
By lifting the tool at an angle, work the tool around the entire perimeter of the keyboard.
Lift the keyboard from the mouse pad.
Use your finger or the spudger tool to flip up the black locking flap.
Grab the black cable and pull away from the motherboard.
Flip up the white locking flap with your finger or spudger tool.
Remove the white cable from the motherboard.
Один комментарий
good afternoon, excuse me, I have a question, I also have the same brand HP Chromebook 14-ca061dx and I just want to know where the anti-write screw is, I want to remove the anti-write screw to install windows 10..
