Введение
This guide shows you how to carefully take out your fan of your HP Chromebook 14-q010nr. Often, a computer overheating is due to issues with the fan. Make sure to power off the Chromebook before beginning.
Выберете то, что вам нужно
Use a Phillips #0 screwdriver to remove the 14 screws securing the base cover under the Chromebook.
Next, open up the laptop to remove the keyboard with a spudger.
Use a Phillips #0 screwdriver to remove the screws securing the fan.
Disconnect the fan from the motherboard my pulling the connector directly out of its port.
