Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide walks through how to remove a malfunctioning camera in an HP Chromebook 14-x013dx. This replacement requires disabling the keyboard from the laptop and removing the lid, and the total repair time should take about 30 minutes.
Запчасти
Детали не указаны.
  1. Using the plastic spudger,  gently lift the 5 rubber pads away from their seating. Using the plastic spudger,  gently lift the 5 rubber pads away from their seating.
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. With the Phillips #00 screwdriver, remove the remaining eight 6mm screws.  You will now have thirteen 6mm screws removed from the case. With the Phillips #00 screwdriver, remove the remaining eight 6mm screws.  You will now have thirteen 6mm screws removed from the case.
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. To continue removing the back cover, turn the laptop over as displayed. Use the plastic spudger to gently pry around the base of the laptop from the back cover.  Continue prying  around the entire base of the laptop.
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  6. Gently lift the silver base of the laptop from the bottom, but do not remove it. To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free. Remove the keyboard panel from the laptop.
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  7. Disconnect the black and white wires connected to the Wi-Fi module. Remove the wire from the casing.
    • Disconnect the black and white wires connected to the Wi-Fi module.
    • Remove the wire from the casing.
  8. Pull the ribbon cable out of socket.
    • Pull the ribbon cable out of socket.
  9. Use a Phillips #00 screwdriver to remove the two 6mm screws located at the upper left and right corners. Use a Phillips #00 screwdriver to remove the two 6mm screws located at the upper left and right corners. Use a Phillips #00 screwdriver to remove the two 6mm screws located at the upper left and right corners.
    • Use a Phillips #00 screwdriver to remove the two 6mm screws located at the upper left and right corners.
  10. Remove the lid out of the laptop. It is helpful to rotate the lid to a 90-degree angle.
    • Remove the lid out of the laptop.
    • It is helpful to rotate the lid to a 90-degree angle.
  11. Using the plastic opening tool, pry the left and right side of the top of the lid.
    • Using the plastic opening tool, pry the left and right side of the top of the lid.
    • It is not necessary to remove the entire frame, only pry the top to expose the camera.
  12. Using tweezers, gently remove the connection hold the camera in place.
    • Using tweezers, gently remove the connection hold the camera in place.
  13. Gently pry the camera mount out of the lid. Lift the camera mount out of the lid.
    • Gently pry the camera mount out of the lid.
    • Lift the camera mount out of the lid.
Заключение
Еще один человек закончил это руководство.
Eile Woeltje
Участник с: 06.11.2019
286 Репутация
Автор 2 руководств
Команда
IUPUI, Team S1-G3, Stella Fall 2019 Участник IUPUI, Team S1-G3, Stella Fall 2019
IUPUI-STELLA-F19S1G3
3 членов
Автор 2 руководств
Один комментарий
Thank you, very helpful. You could also just start at Step 10 without removing the display
Douglas Walker - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 26
За всё время: 155
