Введение
This guide will assist you in successfully replacing the HP Chromebook 14-x013dx Screen. This requires the removal of the bezel around the screen, as well as 4 screws and the connection to the motherboard. Some of the removed parts have adhesive on them which may need to be reapplied.
Note: The replacement of the screen does not require any prior disassembly of the laptop.
Выберете то, что вам нужно
Remove lower left and right nylon flaps on the screen to remove the screws located underneath them.
Remove the two 2mm screws holding the bezel to the laptop case.
Gently pry around the edges of the display using a spudger to remove the bezel that borders the screen.
Once glue is separated, pop out the front cover by pulling upwards on the hinge.
Once the bezel has been removed, remove the four 5mm screws at the corners of the screen using a PH00 screwdriver.
Before completely removing the screen, detach the connected located at the bottom of the screen.
3 участников успешно повторили данное руководство.
