HP Chromebook 14-x015wm Battery Replacement
Выберете то, что вам нужно
  1. HP Chromebook 14-x015wm Battery Replacement, Battery: шаг 1, изображение 1 из 2 HP Chromebook 14-x015wm Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • Turn the Chromebook upside down so that the bottom is facing upwards.
    • Remove the small rubber circles from all four corners.
    • Remove the other three rubber pads from the bottom
    • Proceed to unscrew all the screws.
    • Keep the screws on a magnetic mat or in a secure location and keep track of which screws went where.
  2. HP Chromebook 14-x015wm Battery Replacement: шаг 2, изображение 1 из 1
    • Flip the laptop back over and open it so that the keyboard is revealed to you.
    • Use a plastic opening tool to pry off the keyboard. It's slightly difficult to get off, but go evenly around all four sides until it pops out.
    • Be careful of the ribbons underneath that connect the keyboard to the internal components.
  3. HP Chromebook 14-x015wm Battery Replacement: шаг 3, изображение 1 из 2 HP Chromebook 14-x015wm Battery Replacement: шаг 3, изображение 2 из 2
    • The long, flat, black component that takes up the majority of the space is the battery.
    • All you are required to do is unscrew the screws attached to the battery and then gently remove the battery from the Chromebook.
    • Make sure to keep track of where the screws came from.
Заключение
Cameron Sinclaire
Участник с: 10/27/17
201 Репутация
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 35
За всё время: 1,388
