Введение
In this guide you will be shown how to remove the trackpad from the HP Chromebook CB2L.
Запчасти
Никакие детали не требуются.
  1. Flip the Chromebook over, and starting at the top right or left hand corner of the large blue piece, use the plastic opening tool to remove it. Remove six 4.77mm screws using the Phillips #1 screwdriver. This part has fragile plastic connectors on it.  Do not damage them.
    • Flip the Chromebook over, and starting at the top right or left hand corner of the large blue piece, use the plastic opening tool to remove it.
    • Remove six 4.77mm screws using the Phillips #1 screwdriver.
    • This part has fragile plastic connectors on it. Do not damage them.
  2. Starting at either the top left or right hand corner of the exposed metal piece, use the blue plastic opening tool to remove the back panel. Starting at either the top left or right hand corner of the exposed metal piece, use the blue plastic opening tool to remove the back panel. Starting at either the top left or right hand corner of the exposed metal piece, use the blue plastic opening tool to remove the back panel.
    • Starting at either the top left or right hand corner of the exposed metal piece, use the blue plastic opening tool to remove the back panel.
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Remove four 3.42mm screws using the Phillips #1 screwdriver. Disconnect the battery from the motherboard.
    • Remove four 3.42mm screws using the Phillips #1 screwdriver.
    • Disconnect the battery from the motherboard.
    • Remove the battery.
  5. Remove four 2.57mm screws using the Phillips #1 screwdriver.
    • Remove four 2.57mm screws using the Phillips #1 screwdriver.
    • Remove single 2.43mm screw using the Phillips #1 screwdriver.
  6. Remove the metal piece along the bottom of the trackpad. Use the plastic opening tool to carefully flip the black piece on the ribbon cable holder then remove the ribbon cable. Push the trackpad out from the keyboard side.
    • Remove the metal piece along the bottom of the trackpad.
    • Use the plastic opening tool to carefully flip the black piece on the ribbon cable holder then remove the ribbon cable.
    • Push the trackpad out from the keyboard side.
Заключение
Nathan Petrie
Участник с: 31.10.2018
277 Репутация
Автор 2 руководств
Команда
IUPUI, Team S1-G4, Harley Fall 2018 Member of IUPUI, Team S1-G4, Harley Fall 2018
IUPUI-HARLEY-F18S1G4
3 членов
Автор 2 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 5
За 30 дней: 6
За всё время: 45
