Введение
This guide demonstrates how to remove the rear cover on the HP Chromebook x360 14-da0011dx. This will allow users to remove their lower case and access parts in their device.
Выберете то, что вам нужно
Flip the device over with the hinge facing away from you.
On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
Еще один человек закончил это руководство.
