Введение
This guide outlines how to remove the battery of an HP Chromebook x360 14c-ca0053. The battery supplies power to the entire device and is a very vital part, so it is important to replace it if it is malfunctioning or not working entirely. Lagging, black screen, and frequent shut-downs could be indicative of a malfunctioning battery.
Выберете то, что вам нужно
Use tweezers to peel back the feet on the top and bottom of the Chromebook to reveal four additional screws.
Use a Phillips #1 screwdriver to remove the 4 7 mm screws located at each corner of the device under the grips.
Insert an opening pick between lower case and chassis.
Separate the lower case from the frame by sliding the opening pick along the perimeter until the case releases.
Use a Phillips #0 screwdriver to remove the five 3 mm screws that secure the battery.
