Введение
This guide outlines how to remove the heat sink of an HP Chromebook x360 14c-ca0053. The heat sink functions to conduct heat to the fans without overheating the device. A malfunctioning heat sink could lead to device failure and is indicated by frequent overheating, so it is important to replace it if it is not working properly. Before reassembly, the thermal paste must be reapplied for proper function.
Выберете то, что вам нужно
Use tweezers to peel back the feet on the top and bottom of the Chromebook to reveal four additional screws.
Use a Phillips #1 screwdriver to remove the 4 7 mm screws located at each corner of the device under the grips.
Insert an opening pick between lower case and chassis.
Separate the lower case from the frame by sliding the opening pick along the perimeter until the case releases.
Use a Phillips #0 screwdriver to remove the five 3 mm screws that secure the battery.
Use a Phillips #0 screwdriver to remove the four 3 mm screws that secure the heatsink.
